14 years agoI2C read of De0 nano accelerometer
Hello everyone, I am using de0 nano and would like to try I2C read of accelerometer(ADXL345) that embedded in de0 nano. So I take it that I2C read has the following sequence: 1) generate start...
14 years agoYes sorry, I forgot to finish my sentence. I meant "using generated logic signals as a clock inside FPGAs isn't a good idea". You should generate both I2C_sclk and I2C_sdat in the same always block, clocked with clk_50. You can use a counter to gerenate the I2C_sclk signal and only execute your state machine code when the counter reaches a specific value.
I've asked about acknowledge read because I don't see anything in your code that does that. Sure you put the I2C_sdat in high impedance mode, but you don't seem to do anything to read back the signal value and check that the slave indeed acknowledged its address. Did you check it with signaltap?
