14 years agoI2C read of De0 nano accelerometer
Hello everyone, I am using de0 nano and would like to try I2C read of accelerometer(ADXL345) that embedded in de0 nano. So I take it that I2C read has the following sequence: 1) generate start...
14 years agoThis is my coding. Please somebody out there help me.
// ADXL clock= 500,000samples of 50Mhz/100Hz // ADXL address= 0x1D/11101 module ADXL_Read( clk_50, //clock 50Mhz// key, I2C_sclk, I2C_sdat, ); input clk_50; input [1:0] key; inout I2C_sclk; inout I2C_sdat; reg I2C_sdat; reg [18:0] counter; reg [18:0] counter2; reg [1:0] q; reg [1:0] q2; wire reset_n; reg GO; reg sclk; reg [6:0] sd_counter; reg [6:0] slave_add = 7'b0011101; // DEFINE SLAVE ADDRESS reg [7:0] register_add = 8'b110000; // DEFINE REGISTER ADDRESS reg [7:0] data; //Data that is read initial begin counter = 3'b0; data = 8'b0; end assign reset_n= key[0]; // 50MHz clock is too fast for the our devive // therefore slower clk need to be generated always @(posedge clk_50) begin if (counter == 18'b0) // if counter is 0 begin q = 2'b01; end else if (counter == 19'b111101000010010000) // if counter is the desired value(has the same priority as earlier if) begin q = 2'b00; end else begin q<= q; end end always @(posedge clk_50) begin if (q == 2'b00) begin counter <= counter -1; end if (q == 2'b01) begin counter <= counter +1; end end //Clk for the Signaltap2 // Notify the moment counter is at the desired value or at 0 always @(posedge clk_50) begin if (counter2 == 18'b0) // if counter is 0 begin q2 = 2'b01; end else if (counter2 == 19'b11110100001001000) // if counter is the desired value(has the same priority as earlier if) begin q2 = 2'b00; end else begin q2<= q2; end end always @(posedge clk_50) begin if (q2 == 2'b00) begin counter2 <= counter2 -1; end if (q2 == 2'b01) begin counter2 <= counter2 +1; end end // key[0] is to reset the whole operation // key[1] is to give a start signal always@(posedge q[0] or negedge reset_n) begin if (!reset_n) GO <= 0; else if (!key[1]) GO <= 1; end always@ (posedge q[0] or negedge reset_n) begin if(!reset_n) sd_counter <= 6'b0; else begin if (!GO) sd_counter <= 0; else if (sd_counter < 44) //sd_counter maximum sd_counter <= sd_counter + 1; end end always@ (posedge q[0] or negedge reset_n) begin if (!reset_n) begin sclk <= 1; I2C_sdat <= 1; end else case (sd_counter) 6'd0 : begin I2C_sdat<=1; sclk<=1;end //START 6'd1 : I2C_sdat <= 0; 6'd2 : sclk <= 0; //SLAVE ADDR+Write(Control Byte)7'b0011101 6'd3 : I2C_sdat <= slave_add[6]; 6'd4 : I2C_sdat <= slave_add[5]; 6'd5 : I2C_sdat <= slave_add[4]; 6'd6 : I2C_sdat <= slave_add[3]; 6'd7 : I2C_sdat <= slave_add[2]; 6'd8 : I2C_sdat <= slave_add[1]; 6'd9 : I2C_sdat <= slave_add[0]; 6'd10 : I2C_sdat <= 0; //Write(0) 6'd11 : I2C_sdat <= 1'bz;//Slave ACK //SUB ADDR(WORD ADDRESS)8'b110000 6'd12 : I2C_sdat <= register_add[7]; 6'd13 : I2C_sdat <= register_add[6]; 6'd14 : I2C_sdat <= register_add[5]; 6'd15 : I2C_sdat <= register_add[4]; 6'd16 : I2C_sdat <= register_add[3]; 6'd17 : I2C_sdat <= register_add[2]; 6'd18 : I2C_sdat <= register_add[1]; 6'd19 : I2C_sdat <= register_add[0]; 6'd20 : I2C_sdat <= 1'bz;//Slave ACK //START 6'd21 : begin I2C_sdat <= 1; sclk<=1; end 6'd22 : I2C_sdat <= 0; //SLAVE ADDR+Read(CONTROL BYTE) 6'd23 : I2C_sdat <= slave_add[6]; 6'd24 : I2C_sdat <= slave_add[5]; 6'd25 : I2C_sdat <= slave_add[4]; 6'd26 : I2C_sdat <= slave_add[3]; 6'd27 : I2C_sdat <= slave_add[2]; 6'd28 : I2C_sdat <= slave_add[1]; 6'd29 : I2C_sdat <= slave_add[0]; 6'd30 : I2C_sdat <= 1; //Read(1) 6'd31 : I2C_sdat <= 1'bz;//Slave ACK //Data read(DATA) //Data byte 1 6'd32 : I2C_sdat <= 1'bz; 6'd33 : I2C_sdat <= 1'bz; 6'd34 : I2C_sdat <= 1'bz; 6'd35 : I2C_sdat <= 1'bz; 6'd36 : I2C_sdat <= 1'bz; 6'd37 : I2C_sdat <= 1'bz; 6'd38 : I2C_sdat <= 1'bz; 6'd39 : I2C_sdat <= 1'bz; 6'd40 : I2C_sdat <= 1'b1;//Master ACK //stop 6'd41 : begin I2C_sdat <= 1'b0; sclk <= 1'b1; end 6'd42 : I2C_sdat <= 1'b1; endcase end assign I2C_sclk = (((sd_counter >= 4)&(sd_counter <= 20))|((sd_counter >=24)&(sd_counter <=42)))? ~q[0] : sclk; endmodule
