12 years agoI2C Contoller from BeMicro CV Cyclone V E FPGA or BeMicro Nios II SDK Dev Kits
Just wondering if it is possible to make an I2C controller from either a BeMicro CV Cyclone V E FPGA Development Kit or a BeMicro Nios II SDK Development Kit? I'm not really an FPGA person but I do happen to have these 2 development kits around and I'm in need of an I2C controller to communicate with an SFP+ module. Any ideas that would allow me to use the dev kits I have? Thanks.3 Replies
Yeah, you could use those two kits.
There is a Qsys port of the OpenCores I2C controller on the AlteraWiki http://www.alterawiki.com/wiki/i2c_%28opencores%29 I haven't used it ... I wrote my own before noticing it on the Wiki ... give the Wiki version a try, and if it does not work, let me know, and I'll post my VHDL code. Cheers, Dave - Altera_Forum
Dave,
Thank you for the link. I would be happy to try it although I'm not quite sure how to. :(. Is this a file I can just program into the dev kit? Also, I have downloaded the Quartus II 14 web edition software and the link only has updated the file for 13. Not sure if that makes any difference. Thanks, - Altera_Forum
--- Quote Start --- Thank you for the link. I would be happy to try it although I'm not quite sure how to. :(. --- Quote End --- Ah, so you are "that new" to FPGAs :) So here's what you have to decide ... 1. Am I learning about FPGAs? 2. Do I have to get the SFP+ interface working? I2C is pretty easy to implement using an FTDI USB-to-MPSSE cable ($26) and FTDIs libMPSSE-I2C code ... http://www.digikey.com/product-detail/en/c232hm-ddhsl-0/768-1106-nd/2714139 Before being able to understand how to use the AlteraWiki code, you need to understand how FPGAs work, what Qsys is, what the Wishbone bus is, what the Avalon-MM bus is, what Modelsim is, what Tcl is, etc. Do you have time for that now? Perhaps re-think your "first FPGA experience". Implement the SFP+ interface using I2C, and independent of that, start to learn about FPGAs. For example, have you created designs for your BeMicro-CV or BeMicro-SDK boards? Eg., here's some BeMicro-CV examples ... http://www.alteraforum.com/forum/showthread.php?t=43992 Cheers, Dave
