AKAYA
7 years agoi need to know if we can dumb one .pof file and then read another .rpd file in UFM
here am creating two project at a time. i will dump one of the .pof file and then i need to read another projects .rpd file through serial terminal. once the .pof file is dumped then the fpga should...
ShafiqY_Intel
7 years agoHi AKAYA,
Yes, it is possible. However you need to have IP to control the Flash.
For example, if you using MAX 10, you need to have On-Chip Flash IP in order to control the flash. First, you need to disable write protection (any sector you want), erase that sector, and write new .rpd file into it.
