i need to know if we can dumb one .pof file and then read another .rpd file in UFM
Hi AKAYA,
I'm apologize for late reply. I didn't realize your reply.
Yes, we can write/read data through the UART.
As long as your UART interface is okay (using our UART IP or your custom UART interface), you should able to use UART.
Below is the UART interface with NIOS II Processor example.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an741.pdf
I hope this will help.
Thanks😉
thanks for the reply....
I can communicate through the UART. But the problem is in reading other application file which is not created for the .pof file.
it works like only once we dump the .pof file in the FPGA. after that it should be able to read any .rpd file as and when required.
is this possible???
kindly waiting for the reply.... please do reply soon....
