I have simple code question
Hi:
I am very beginner. I wrote very simple code for DE10-Nano board to turn on one LED, but it is not working. Maybe someone could help:
module LED (
CLK_50,
LED1
input CLK_50;
output reg LED1;
integer counter=0;
always @*
begin
//LED1 <= 0;
counter <= counter + 1;
if(counter == 200000)
begin
LED1 <= 1;
//counter <= 0;
end
if(counter == 400000)
begin
LED1 <= 0;
counter <= 0;
end
end
endmodule
After programming, LED1 never ever turn ON. I tried many different values in Counter, and still nothing.
My understanding is that when Counter is between 200000 - 400000, then LED1 will turn ON.
Thanks in advance.
- sstrell
You haven't set up your always block correctly. Since you're creating a counter, it should probably be:
always @ (posedge CLK_50)
Without a clock, the way your code is written, nothing will happen (the counter will never increment).
#iwork4intel
- AnandRaj_S_Intel
- Check your Pin assignments.
- Check you code in modelsim (@* includes all the inputs used in block) or debug using signal tap.
- You have used smaller counter value, the led is toggling at 125 Hz because of which we can't see it.
- Try to toggle the led at less than 40 Hz.
Or just use switch and led to start with.
module LED ( input SW, output LED ); assign LED= SW; endmoduleLet me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand
- imarz1
Hi:
I can turn ON LED by: LED1 <= 1;
Also, the CLK_50 is set to pin_V11.
So, probably it is not pin assignment issue.
The problem seems to be when creating time delay before turning ON the LED... I am unable to create any time delay.
For example the following delays did not work:
1- if(counter == 200000)
2- for (i = 0; i < 500; i = i +1) : Here i found out I can't have more than 500 iteration in FOR loop ? Not sure if this is verilog restriction or Quartus issue.
3- repeat(500) : Here too, I can't have more than 500 iteration ? Same, not sure if this is verilog restriction or Quartus issue.
In all these three cases the LED turns ON immediately. The delays were nothing, even though I looped many "repeat(500)" within the For loop.
Remember, I am very beginner, so I might have made a rookie mistake somewhere...
