I have cyclone 10 lp FPGA with cypress serial flash as the configuration device. In order to burn my firmware to the flash (using jtag and Active Serial mode) I want to use pof file. Is it a problem?
As in the post Quartus tool edition/version & part number of cypress serial flash are missing so I would like to suggest the following various solution
1.First try with .pof file with “Disable EPCS ID Check” except Quartus tool v12 & v13
http://www.cypress.com/file/195256/download
2.Try with Jtag Indirect file(.jic) with “Disable EPCS ID Check” However, if the Quartus Programmer cannot properly detect the Cypress device, then refer the link below for an alternate method to in-system program the Cypress SPI flash by using Altera’s Nios II tool, which works with all versions of Quartus tool.
http://www.cypress.com/file/202476/download
Best Regards
Vikas Jathar
