PPoka1
7 years agoi have arria 10 gx development board from altera. i tried to use lcd example code from altera https://fpgacloud.intel.com/devstore/platform/16.1.0/Standard/arria-10-gx-lcd-display-reference-design/ but there are some error
i am using quartus 19.2 i am not able to update q_sys and there is also some error reguarding 12c opencore
KennyT_altera
7 years agoThere will be some problem if you update your IP jumping the version too far from Q16.1 to Q19.2. What you can do is reinstantiate the IP manually. The setting should be in the .ip files
PPoka1
7 years agohow can i manually install. i tried using upgrade in editor
