Gerard_M_Intel
7 years agoI have a supplier using the DK-DEV-5CSXC6N. Using the on-board USB-Blaster circuitry they can successfully run debug sessions on both the HPS and the FPGA. However when using an external USB-Blaster not so much.
I have a supplier using the DK-DEV-5CSXC6N. Using the on-board USB-Blaster circuitry they can successfully run debug sessions on both the HPS and the FPGA. However when using an external USB-Blaster ...
JohnT_Altera
7 years agoHi,
May I know if yo are using USB-Blaster or USB-Blaster II? If you are using USB-Blaster II then I would recommend you to change the TCK clock frequency to 6Mhz.
