CWarr1
7 years agoI have a faulty Arria-10 SoC board. Please advise how to obtain an RFD so I can return the board to Mouser. Thanks!
fault Description: Board checked and tested as per “getting started” section of user guide Board switches and jumper settings confirmed to be as expected. I am using the SD card supplied with t...
AR_A_Intel
7 years agoHello
Welcome to INTEL forum. The failure description you provided is too general to understand the actual failure behavior at your site. Can you give me a little background/elaborate on how you installed EMIF DDR3 or DDR4 HILO, did you install the card correctly? This is to rule out whether the damaged part is on EMIF HILO card or the dev kit board itself.
Could you also help check whether you using dev kit board reference design following exact Quartus version as specified in reference design doc. Advise the Quartus version use?
CWarr1
7 years agoHi AAdb,
We have several of these boards, so I am reasonably confident that the card, and the HIOL modules are installed correctly.
The 2 Micron branded HILO memory modules were installed in a static-safe work environment. They are labelled “Altera DRAM X72 daughter card”
I have installed these previously with no problems.
I have tried re-installing and swapping them, and also swapped them with another Arria-10 dev board. The problem stays on the faulty Arria10 dev kit card, and the HILO cards work OK when installed into a known good dev kit.
For SD cards, I am using the card that came with the board.
Please find attached 2 logs:
terminal - Intel SD card.txt is the SD card that was shipped with the dev kit
terminal - PTL SD card is the SD card generated here using Quartus 16.1.0
the results are similar.
Please advise if there are any other tests you can suggest that I could carry out.
Chris
