I can't get my USB Blaster to be recognized by the Quartus Prime 18.1 Programmer.
Thank you for your response to my question. I am using the Cyclone 10LP FPGA Evaluation Kit and it works via the MAX 10 USB Blaster on board. However, I want to use the JTAG Header to do NIOS Debug and Signal Tap operations for logistical reasons. I have tried every which way in all sorts of combinations to reinstall the USB Blaster Drivers more than 10 times. When the USB Blaster gets plugged in, it shows up in Device Manager under ‘Other devices” with the name “USB-Blaster”. When I try to “Update the Driver” as instructed by Intel/Altera in their USB Blaster Installation Guide, I get the following message from the Windows 10 Driver Update Box “Windows was unable to install your USB-Blaster”, “windows could not find drivers for your device”. I am lost. I have no idea how to get around this problem. See below for the Update Drivers Message that I have gotten at least 10 times as I have tried to install the USB Blaster.
Thanks for any guidance you might be able to provide me,
Bill
William Sheppard Electronic Design
8520 E Kael St
Mesa, Arizona 85207
480-225-7731
