BStui2
6 years agoI can successfully run the design example from PCIe IP guide for A10 devkit, however when I exchang the onchip_memory2_0 component with my own it hangs the PCIe bus.
I can successfully run the design example from PCIe IP guide for A10 devkit, however when I exchang the onchip_memory2_0 component with my own it hangs the PCIe bus. With the MEM component connected...
SengKok_L_Intel
6 years agoHi,
If this is the case, I would suggest capturing the signal tap at the interface of your custom component with and without appearing of On-chip memory. So that we can compare the difference. Probably something minor that not compliant with AVMM spec.
Regards -SK
