rmclo
7 years agoI am using an Arrow SoCkit Cyclone V .programmer starts to run but fails after 60%
I have set the the program mode 4x active serial, set the MSEL 10010 converted the file to jic with "convert File" and start the down load after approx60% it fails. The leds on the board go off as if...
YuanLi_S_Intel
7 years agoHi Robert,
If you are able to program SOF successfully, that means OPN is not an issue. It is due to switch setting on the board and also the generated bitstream. Just would like to check, during JIC file generation, what memory device you selected? have you selected 128MB QSPI Flash? Also, please change all switches to default position except MSEL to ASx4 configuration mode.
YL
