rmclo
7 years agoI am using an Arrow SoCkit Cyclone V .programmer starts to run but fails after 60%
I have set the the program mode 4x active serial, set the MSEL 10010 converted the file to jic with "convert File" and start the down load after approx60% it fails. The leds on the board go off as if...
YuanLi_S_Intel
7 years agoHi Robert,
Can you check if you are selecting the correct OPN in your design? The simple way to check is to program the SOF file. If it is successful, that means that the configuration setting is not correct.
YL
