huge delay inserted by Quartus 19.3 pro on the Arria 10 FPGA
I have been looking further into this,
apparently Quartus 19.3, for the Arria X FPGA,
has issue with clear/preset/clk constructions, that gives a combi loop (but not the case with quartus 13.1 and the stratix 3):
Example below:
if (!cd) q <= `unitdelay 1'b0;
else if (!sd) q <= `unitdelay 1'b1;
else q <= `unitdelay d;
end
Combi loop in the timequest analyzer:
Found combinational loop of 3 nodes
Node "rfd_ic_i|u_top|u_core|u_flash_subsys|A_ip_pflash640k_atfc|u_controller|u_fmc_if|read_fail_sync_reg|q~1~la_mlab/laboutt[6]"
Node "rfd_ic_i|u_top|u_core|u_flash_subsys|A_ip_pflash640k_atfc|u_controller|u_fmc_if|read_fail_sync_reg|q~1|dataf"
Node "rfd_ic_i|u_top|u_core|u_flash_subsys|A_ip_pflash640k_atfc|u_controller|u_fmc_if|read_fail_sync_reg|q~1|combout"
Note the presence of the la_mlab/laboutt[6] again.
How to solve this issue, keeping the same RTL code?
Second (vhdl) example:
process(scl_clk_n, rstn, start_stage1,scantestmode)
begin
if(rstn = '0') then
start_stage2 <= '0' after delay_f;
elsif(start_stage1 = '1' and scantestmode = '0') then
start_stage2 <= '1' after delay_f;
elsif(scl_clk_n'event and scl_clk_n = '1') then
end if;
end process;
Node "rfd_ic_i|u_top|u_core|u_atlas|A_flexcomm_array[1].A_flexcomm|A_flexcomm|A_bi2c_gen.A_bi2c_core|slave_detect_inst|start_stage2~1~la_mlab/laboutt[0]"
Node "rfd_ic_i|u_top|u_core|u_atlas|A_flexcomm_array[1].A_flexcomm|A_flexcomm|A_bi2c_gen.A_bi2c_core|slave_detect_inst|start_stage2~1|dataf"
Node "rfd_ic_i|u_top|u_core|u_atlas|A_flexcomm_array[1].A_flexcomm|A_flexcomm|A_bi2c_gen.A_bi2c_core|slave_detect_inst|start_stage2~1|combout"
