19 years agoHSMC Specification
Hello, the Cyclone III FPGA Starter Board Reference Manual says: "For more information regarding the HSMC, refer to the High Speed Mezzanine Card Electrical and Mechanical Specification ve...
14 years ago --- Quote Start --- You can use the differential pairs as 2 single ended I/Os. You can of course use only one pin of the pair and leave the other unconnected. --- Quote End --- How to use differential pairs as 2 single ended IO? What configuration to set in Quartus or hardware? As far as I know, I thought to use single ended IO, I just need to reconfigure it at pin planner so that it has IO standard 2.5V instead of LVDS isnt it? Please correct me if I am wrong because I am currently configuring the HSMC pins. thank you.
