19 years agoHSMC Specification
Hello, the Cyclone III FPGA Starter Board Reference Manual says: "For more information regarding the HSMC, refer to the High Speed Mezzanine Card Electrical and Mechanical Specification ve...
17 years ago --- Quote Start --- Hi, fall, I am also interested in this eagle footprint. Would you please send it to [email protected]? Also, a starter's question: I may need to build a test board with HSMC connector. What's the best way to have the HSMC connector mounted on the test board? (I may use expressPCB, so the board will has no component on it) Is it possible to mount it by myself? Thanks very much, Kevin --- Quote End --- The easiest way is to use the pin out board: http://www.bitec.ltd.uk/hsmc_proto.html
