19 years agoHSMC Specification
Hello, the Cyclone III FPGA Starter Board Reference Manual says: "For more information regarding the HSMC, refer to the High Speed Mezzanine Card Electrical and Mechanical Specification ve...
19 years ago --- Quote Start --- I am not aware of any existing spec released by Altera, however you can buy the HSMC connectors from Samtec and make your own expansion cards for the new dev kits. --- Quote End --- I already have the Samtec Connector (ASP-122952-01) because i want to build an expansion board for the Cyclone III Development Kit. (If somebody is interested in an EAGLE footprint for this connector, let me know.) --- Quote Start --- For pinout/signal names on the CIII kit, see the files in Schematic folder you get when you install the software which comes on the CD in the box. --- Quote End --- The pinout/signal names for the HSMC connector is the point i'm interested in! Your proposal was the correct location: In the document "CycloneIII_SB_3C25.pdf" on page 11 you can find the HSMC connector. Thanks!
