HSMC GPIO Daughter card.
I have a question regarding the gpio-hstc card (http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=67&no=322&partno=1). I'd like to use this board to expand the gpio of my DE2-115 dev. board. In the documentation it states that the HSMC connector pins are connected to GPIO pins. Am I correct in thinking that there is no need for a driver in my design? Meaning I can just map a HSMC pin as if it is a GPIO pin, or do I need to do something more.
If you have any tips regarding the use of the board, I'd like to hear them as well.18 Replies
Yes, you are correct. This adapter map HSMC pins only. Not need to have special driver
thank you. I'll try to remember to post any tips I might think of when I have finished this project.
Well I had a lot of other stuff to get working before I managed to do something with this adapter. But found that I had trouble when using the HSMC_TX_D_P[9?]. This is assigned to the same pin as nCEO. I remember reading something about this but I could not remember the solution. After about 30 minutes I remembered having a similar problem with another board once (I beleve it was the DE2-70) where a pin was configured as a programming pin.
So for others who encounter this and immediately search this forum: 1. Go to Assignments->Device->Device and Pin Options... 2. Open menu Dual-Purpose Pins 3. Set nCEO from "Use as programming pin" to "Use as regular I/O". - Altera_Forum
For others who would like to use this adapter, I will give my pin assignments file and the pinout I got from Terasic. I still have one problem, the HSMC_RX_D_N(15) is always high. If I have figured out why, I will post this as well.
Hi there,
Thanks for sharing the tips with others. I had the same problem when I built a new project from scratch for the first time. Could you upload your project or send it to our support mail at [email protected] ? We'd like to take a look and see what's going on here. David from Terasic - Altera_Forum
@David, I will send you a mail in a couple of days. Is there other info you will need?
[edit] Do you also need all the VHDL files, or is just the project enough? If you want the vhdl code I can setup an example. - Altera_Forum
Hi there,
If it's alright with you, a complete project would be nice. I would like to get started by compiling the project here. I'll keep you posted if we need any other info. Thanks, David from Terasic - Altera_Forum
I have setup a quick test which has the same problem. It is always 2.12/2.11 volts whithout attaching any load, just a multimeter. Attached is the project and the sof file for a DE2-115 board with the Daughter card. I know the coding might not be as it should, but it is something I have quickly set up.
I am beginningn to think we need to start a new thread about the pin voltage. I just found out that HSMC_TX_D_p(16) gives 2,38V when high, and HSMC_RX_D_p(15) provides 2,42V. This seems to be a small difference, but I use these two pins (among other pairs with similar problems) to control a motor[controller], and then it transmits a PWM signal, and the difference becomes a problem. The motor does turn one way, but not the other. Any suggestions? Should I change the jumper to select another IO standard, this might make the difference proportionally smaller, but the main problem still exists.
@David, Do you know some workaround? I have done all other things on my project for now, and really need the extra IO in order to continue.
