18 years agoHSMC debug header cyclone III dev kit
Hello, I would like to use the HSMC debug header supplied with the Cyclone III dev kit but there is no datasheet showing its internal connections. Is there someone who know where i could find ...
14 years ago --- Quote Start --- A breakout-header schematic is included with 3C120 Dev. Kit, check if it's the same! --- Quote End --- Looked through the schematic and seems that on the breakout-header, Bank2 IO can be used as GPIO for testing/other usage, while Bank3 is already internally connected to resistors and LEDs with differential signaling of 2 pins per pair. Thus Bank3 cant use as GPIO on the breakout-header. Please advice if I interpret it correctly.
