TNGUY312
6 years agoHPS Programming to FPGA
I have Altera Cyclone V Soc and currently using Quartus (Quartus Prime 17.1) Lite Edition. I want to create connection between HPS and FPGA. I want to generate FPGA signal output from HPS Linux.
AnilErinch_A_Intel
6 years agoHi
You can use the platform designer to connect the IP, you don't have to recompile the kernel , but you will have to enable the bridges from the uboot , as per the commands given in the section FPGA Configuration from U-boot in the link provided above.
You can try first without enabling the bridges and then try after enabling the bridges. Please let us know the results.
Thanks and Regards
Anil
