hps_a10_common_board_info.xml hps_a10_devkit_board_info.xml qsys_top_board_info.xml
My question are
#1. Were those three files (see below), which are board xml files generated by Quartus?
1). hps_a10_common_board_info.xml
2). hps_a10_devkit_board_info.xml
3). qsys_top_board_info.xml
It seems not according to the "Generating the Linux Device Tree" flow overview. Where the sopcinfo is from Quartus.
#2 Was there any settings in Quartus to generate these three files? or under which folder of Quartus project?
The Quartus generates xml files in "handoffs" for uboot. There are also a bunch of xml files at per peripheral basis.
1. Yes. In the Device tree generator, it assumes that the GHRD (which is the golden reference hardware design) already have the XML which is precompiled. That is why the flow is as such.
2. There are no additional settings, 3 XML files are generated automatically when running Compile in Quartus and will be in the Quartus Project folder.
