XG_Kang's avatar
XG_Kang
6 years ago
how to use GPIOs in ddr3l bank
If one IO bank is assigned to DDR3L controller whose logic level is SSTL-135 Class I, how the unused gpio can be used? what logic level should assigned to those gpio?
  • Hi XG_Kang,
    May I know how you're implementing the controller, is it soft or hard?
    As mentioned above, if it is hard, you may not be able to use other pins in that I/O bank as GPIO
    Matt
  • sstrell's avatar
    sstrell
    It depends on the target device family and how you're implementing the controller: soft or hard? If it's hardened, like in newer devices, you may not even be able to use the other pins in the I/O bank as GPIO. What's your target device?
    #iwork4intel
      • ShafiqY_Intel's avatar
        ShafiqY_Intel
        Hi XG_Kang,
        Matt
