CKang11
7 years agohow to use get_device_names
hi.I have some problems in FPGA . Now i am debugging my application using VJTAG. but I cannot get the device name using get_device_names' The command is exec C:\\altera\\10.0\\quartus\\bin64\\quartu...
KhaiChein_Y_Intel
7 years agoHi,
Do you see any error message?
CKang11
7 years agocould the command device _lock lead to it? According to the manual , device_lock Description
Obtain an exclusive JTAG communication to the devicefor the subsequent IR and DR shift operations.
The device must be locked before any instruction and/or data register shift operation.
This should be used as little time as possible as it denies the access of other applications to this chain. The
command, unlock, should be called as soon as possibleto allow other applications to access the device.
