CKang11
7 years agohow to use get_device_names
hi.I have some problems in FPGA . Now i am debugging my application using VJTAG. but I cannot get the device name using get_device_names' The command is exec C:\\altera\\10.0\\quartus\\bin64\\quartu...
KhaiChein_Y_Intel
7 years agoHi,
May I know if you have any updates?
CKang11
7 years agohi, the question is solved. the command must run in the xterm. i want to know if virtual jtag and signal tapII can run for debug in one project at the same time ? I try running vjtag and signal tap II at the same time ,but the signal tap II can not be trigered .why? Is it because they share one jtag interface , which make them not be used at the same time?
