Veerappan's avatar
Veerappan
1 year ago
How to use FPGA-to-hps free clock as HPS clock source?
In our custom board, an external oscillator is working but the PLL lock does not happen, so we decided to use FPGA-to-HPS free clock or HPS internal clock. We enabled FPGA-to-HPS free **bleep** in the input clocks tap and selected FPGA-to-HPS free **bleep** as a source for the main and peripheral reference clock in the internal and output clock tap in HPS_IP. Again same issue it is stuck at the PLL lock.
I am new to the FPGA side please give a procedure to configure these HPS three-clock sources.
Veerappan P.
  • KianHinT_altera's avatar
    KianHinT_altera
    Hi Veerappan,
    Apologies for the long delay in replying , was on medical leave for 2 weeks and my forum account access got revoked, just manage to regain access this week.
    I will look into this case and feedback to you later, once again I'm sorry for the long response delay.
    Kian
    KianHinT_altera
    Hi Veerapan,
    Was discussing your issues with our team here, could you help provide all the error logs that you see when booting (including the pll unable to lock) and also from your screenshot, there is 3 warnings on the bridges, could you confirmed the connections to the bridge is there?
    something like this example that I saw in another case on the bridge connections
    https://community.intel.com/t5/Programmable-Devices/Enabling-HPS-FPGA-bridges-on-Agilex-7/td-p/1631179
    In addition, could you provide us with the design files as well?
    Kian
    KianHinT_altera
    Hi ,
    May I know the status of this case, whether you could provide more information on this?
    Kian
    KianHinT_altera
    But to illustrate again , do follow these steps
    1. Enable the FPGA-to-HPS Free Clock: In the input clocks tab, enable the FPGA-to-HPS free clock. This will allow you to use it as a clock source (which enabled but just reconfirm)
    2. Select the Clock Source: Choose the FPGA-to-HPS free clock as the source for the main and peripheral reference clocks in the internal and output clock tab in the HPS IP (which already enabled but do confirm this)
    3. Configure the PLL: Ensure that the PLL (Phase-Locked Loop) is properly configured to lock onto the FPGA-to-HPS free clock. This might involve setting the correct parameters for the PLL to achieve a stable lock.
    4. Check Connections: Verify that all connections to the HPS-FPGA bridges are correctly configured. This includes ensuring that the bridges are enabled and properly connected.
    5. Debugging: If you encounter issues such as the PLL not locking, check the error logs and warnings related to the bridges and clock configurations.
    Kian
