How to use FPGA-to-hps free clock as HPS clock source?
But to illustrate again , do follow these steps
Enable the FPGA-to-HPS Free Clock: In the input clocks tab, enable the FPGA-to-HPS free clock. This will allow you to use it as a clock source (which enabled but just reconfirm)
Select the Clock Source: Choose the FPGA-to-HPS free clock as the source for the main and peripheral reference clocks in the internal and output clock tab in the HPS IP (which already enabled but do confirm this)
Configure the PLL: Ensure that the PLL (Phase-Locked Loop) is properly configured to lock onto the FPGA-to-HPS free clock. This might involve setting the correct parameters for the PLL to achieve a stable lock.
Check Connections: Verify that all connections to the HPS-FPGA bridges are correctly configured. This includes ensuring that the bridges are enabled and properly connected.
Debugging: If you encounter issues such as the PLL not locking, check the error logs and warnings related to the bridges and clock configurations.
Kian
