How to tri-state the configuration pins after configuration with CycloneV?
Hello
Thank you for your efforts.
I checked the obtion in the .qsf file (see picture below).
We did not record any waveforms. We just tried to set the pins we wanted to tri-state to a 2.5V potential after configuration.
If they were tri-state we should measure 2.5 V at the point shown in the picture below. But for two of the pins we measure 0V so they seem to
be driven to GND and not tri-state.
regards
- ShafiqY_Intel6 years ago
The output will be high or low depending upon its output logic level.
I don't think you can just simply measuring using above circuit to determine whether pins are tri-state or not.
The more practical way to determine is include ASMI Parallel IP (I or II) in your design. Then, if the DCLK, nCSO and DATA pins are tri-stated, these pins will prevent ASMI Parallel IP from working correctly in user mode.
I hope this will help.
Cheers.
