JSieg4
6 years agoHow to tri-state the configuration pins after configuration with CycloneV?
Hello, We work with a CycloneV in active serial configuration mode. The EPCS config flash is connected to the FPGA and also in parallel to an external microcontroller. The idea is to update the FPG...
JSieg4
6 years agoHi,
Sorry for the vague question.
I mean DATA0, nCSO and DCLK.
There is this option under: Assignements/Device/Device and Pin Options/Configuration/Enable input tri-state on active configuration pins in user mode
If i understand this link correctly, then this should do the trick
https://www.intel.com/content/www/us/en/programmable/quartushelp/17.0/mapIdTopics/mwh1465495267624.htm
but somehow the pins are not tri-stated even with this option enabled.
We are working with active serial configuration scheme.
I'm using quartus 18.0
regards.
- ShafiqY_Intel6 years ago
Hi JSieg4,
If possible, can you send your design?
and also, send the screenshot of "the pins are not tri-stated even with this option enabled."?
I want to duplicated on my side.
Cheers
