JSieg4
6 years agoHow to tri-state the configuration pins after configuration with CycloneV?
Hello, We work with a CycloneV in active serial configuration mode. The EPCS config flash is connected to the FPGA and also in parallel to an external microcontroller. The idea is to update the FPG...
JSieg4
6 years agoHello
Thank you very much for the answer.
OK, i see that the pins can't be used as GPIO's after configuration in Cyclone V devices.
But is there another possibility to tristate them after configuration?
Thanks in advance!
regards
- ShafiqY_Intel6 years ago
Hi JSieg4,
What pins you refer to "them"? nstatus pin or any pin?
Cheers
