JSieg4
6 years agoHow to tri-state the configuration pins after configuration with CycloneV?
Hello, We work with a CycloneV in active serial configuration mode. The EPCS config flash is connected to the FPGA and also in parallel to an external microcontroller. The idea is to update the FPG...
ShafiqY_Intel
6 years agoHello JSieg4,
For Cyclone V device, only these pins can use as user I/O pin after configuration:
- CLKUSR
- DEV_OE
- DEV_CLRn
- DATA[15...5]
Below is example how I use DEV_OE pin as I/O pin after configuration.
Pin information for Cyclone V device I used:
Others Configuration pins (ie DCLK, nstatus, etc2), you cannot use it as I/O pin after configuration as this pins are dedicated pin.
I hope it is clear now.
