How to transfer data from FPGA to HPS DDR
- 3 years ago
After testing, using the mmap function on the HPS side can read data from HPS DDR. I referred to https://github.com/zangman/de10-nano/blob/master/docs/FPGA-SDRAM-Communication_-Avalon-MM-Host-Master-Component-Part-3.md and used the mmap function to operate on HPS DDR, resulting in the same results as Zangman's.
In cycloneV soc(de10-nano), the starting address of HPS DDR is 0x0000000 and the ending address is 0x3FFFFFFF.
/* code for operating HPS DDR */ #include <stdio.h> #include <stdlib.h> #include <fcntl.h> #include <sys/mman.h> #define HPS_DDR_BASE 0x00000000 #define HPS_DDR_SPAN 0x40000000 #define HPS_AXI_BASE 0xC0000000 int main() { int fd; void *hps_ddr_base; void *h2f_base; int *addr1; int *addr2; // Open /dev/mem device fd = open("/dev/mem", O_RDWR | O_SYNC); if (fd == -1) { perror("could not open /dev/mem\n"); return 1; } hps_ddr_base = mmap(NULL, HPS_DDR_SPAN, PROT_READ | PROT_WRITE, MAP_SHARED, fd, HPS_DDR_BASE); h2f_base = mmap(NULL, 0x1000, PROT_READ | PROT_WRITE, MAP_SHARED, fd, HPS_AXI_BASE); if (hps_ddr_base == MAP_FAILED) { perror("could not mirror HPS DDR3 to user space\n"); close(fd); return 1; } // Write 0xAA to 0x20000000 addr1 = (int*)(hps_ddr_base + 0x20000000); *addr1 = 0xAA; // Write 0x1 to 0xC0000000 addr2 = (int*)(h2f_base); *addr2 = 0x1; // Unmap and close the /dev/mem device munmap(hps_ddr_base, HPS_DDR_SPAN); close(fd); return 0; }Thank you again for your help. Please close this thread, Adzim.
Regards.
I'm not so used to mSGDMA module. There are some resources for the mSGDMA module in the Embedded Peripherals IP User Guide. Link: https://www.intel.com/content/www/us/en/docs/programmable/683130/23-1/modular-scatter-gather-dma-core.html
mSGDMA Design Example: https://community.intel.com/t5/FPGA-Wiki/MSGDMA-design-example/ta-p/735335
I'm sorry if I can't help you for this question. But you still can create another thread and ask for that specific question.
Adzim
- 22584323 years ago
Thanks again for your help. I would like to ask another question, how to read data from HPS DDR on the HPS side? Can I use the mmap function to do this? If possible, I don't know the mapping address for HPS DDR. In https://www.intel.com/content/www/us/en/programmable/hps/cyclone-v/hps.html , I didn't find the address for HPS DDR.
regards.
Regards.
