2258432's avatar
2258432
3 years ago
How to transfer data from FPGA to HPS DDR
Hi, I have two cyclone V soc boards, and I am working on a design to transmit video data generated from the FPGA side of the first board to the second board through HPS Ethernet, and finally display...
  • 2258432's avatar
    2258432
    3 years ago
    After testing, using the mmap function on the HPS side can read data from HPS DDR. I referred to https://github.com/zangman/de10-nano/blob/master/docs/FPGA-SDRAM-Communication_-Avalon-MM-Host-Master-Component-Part-3.md and used the mmap function to operate on HPS DDR, resulting in the same results as Zangman's.
    In cycloneV soc(de10-nano), the starting address of HPS DDR is 0x0000000 and the ending address is 0x3FFFFFFF.
    /* code for operating HPS DDR */
    #include <stdio.h>
    #include <stdlib.h>
    #include <fcntl.h>
    #include <sys/mman.h>
    #define HPS_DDR_BASE 0x00000000
    #define HPS_DDR_SPAN 0x40000000
    #define HPS_AXI_BASE 0xC0000000
    int main() {
        int fd;
        void *hps_ddr_base;
        void *h2f_base;
        int *addr1;
        int *addr2;
        // Open /dev/mem device
        fd = open("/dev/mem", O_RDWR | O_SYNC);
        if (fd == -1) {
            perror("could not open /dev/mem\n");
            return 1;
        hps_ddr_base = mmap(NULL, HPS_DDR_SPAN, PROT_READ | PROT_WRITE, MAP_SHARED, fd, HPS_DDR_BASE);
        h2f_base = mmap(NULL, 0x1000, PROT_READ | PROT_WRITE, MAP_SHARED, fd, HPS_AXI_BASE);
        if (hps_ddr_base == MAP_FAILED) {
            perror("could not mirror HPS DDR3 to user space\n");
            close(fd);
            return 1;
        // Write 0xAA to 0x20000000
        addr1 = (int*)(hps_ddr_base + 0x20000000);
        *addr1 = 0xAA;
        // Write 0x1 to 0xC0000000
        addr2 = (int*)(h2f_base);
        *addr2 = 0x1;
        // Unmap and close the /dev/mem device
        munmap(hps_ddr_base, HPS_DDR_SPAN);
        close(fd);
        return 0;
    Thank you again for your help. Please close this thread, Adzim.
    Regards.
