iiwan
6 years agoHow to tell quartus for multiple clock
I have part of my disign for Stratix V, that works on rx_std_clkout and tx_std_clkout from Transceiver Native PHY IP core, and dynamically change speed via Transceiver Reconfigurator IP core. I use w...
CheepinC_altera
6 years agoHi,
Thanks for your update. Yes, you are right, when you perform dynamic reconfiguration, the tx/rx_clkout frequency will change according to your new XCVR data rate.
Would you mind to further elaborate on what is referred by "it works not good as I expected"? For example, do you observe your core logic behave incorrectly?
Chee Pin
iiwan
6 years agoYes, my core logic not working well. After dynamic reconfiguration to 5Gbps(125Mhz) my logic approx in 80 % of case work good, but to 10Gbps(250Mhz) not working at all.
P.S. For example can you tell how to make sdc file to tell, that my modules have to work at 3 freq, like Ethernet Triple(1, 2,5 and 10G) speed. Or I have to do something another way?
