Dzar
7 years agoHow to tell DS-5 which chip to connect to?
I have a board with two Cyclone V devices on it and both have dual ARM processors in them. When I connect to my JTAG chain with DS-5, it happily connects to one of them but how do I now which one? An...
FawazJ_Altera
7 years agoHello Dzar,
Kindly note that this is not a standard support issue, since it is a rare case that 2 FPGA's on the same board with one JTAG connection.
May I know if you are using one USB blaster or 2 on board?
Furthermore, I would like to see the output of jtagconfig -n (you can run it in SoC EDS command shell).
usually from DS5, go to Debug configuration > Bare Metal Debug > Browse > and lets see how the JTAG chain view these FPGAs.
Once you select which FPGA, you can select which ARM you want. You cannot view 4 ARMs on the same time since one FPGA should be selected.
