CAlex's avatar
CAlex
3 years ago
How to setup a time interrupt on de10 standard using C language
Hi, I'm a rookie of the SoCFPGA and I wanted to use it to build a FSM in HPS.
I have already finished building the system design as "User Manu" said and get the hps_0.h header file out.
I built my system based on the GHRD, and added a timer(100ms) using the Altera IP.
Now I want to play with it,yet there are little information about a timer or an interrupt working on SOC.
The board I'm using is a DE10-standard board.
Could anyone show me where to start?
And it will be better if you can provide a document/example on how to play with the Altera IP on C.
Thank you for your help.
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi Alex
    Did you manage to test out the suggested changes?
    Jingyang, Teh
  • CAlex's avatar
    CAlex
    I'm a little busy on other things right now,
    please give me a couple of days.
    Reguards.
    tehjingy_Altera
    Hi Alex
    Do you still need some extra time for this case?
    Jingyang, Teh
    tehjingy_Altera
    Hi
    Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
    Jingyang, Teh
