12 years agoHow to set up a transceiver in Arria V GX development kit?
Hello, I have the Arria V GX 5AGXFB3H4F40C5. I program it with Quartus II 13.1 in windows 8.1 the questions are at the end of this message. I'm trying to set up one transceiver as tra...
12 years agoThanks for answering!
I'm using SMA connectors. I have disabled the loopback option cause I look the signal output in an oscilloscope. I connect the J5 with the probe of my oscilloscope with an SMA wire. Now I know that the PIN_G32 and PIN_G31 are the pin numbers for my reference board SMA connector J5, positive and negative respectively. Also I have done the same project without reconfiguration controller, working only at 1GHz and using a custom PHY Transceiver instead of Native. And now it is working, it is sending data by J5 board reference connector. Furthermore I have not warnings. May be important to say that my logic block, written by me in VHDL, is in this design. So I know is ok. I will do the receiver part now, I won't try to use the reconfiguration controller any more. can any one tell me the pin numbers for my sma rx board reference connector j3?
