TLemo
7 years agoHow to send data between Cyclone V FPGA and HPS on DE0-Nano-SoC?
We're trying to modify and existing FPGA program running on the FPGA portion of the Cyclone V to send data to the HPS portion of the Cyclone V, but cannot find any helpful documentation. I am pretty...
FawazJ_Altera
7 years agoHello,
You can refer to the datamover example:
https://rocketboards.org/foswiki/Projects/Datamover#Obtain_FPGA_44_Linux_and_NiosII_Binaries
it shows how to transfer data between FPGA and HPS. The design files were removed since it was using an older version of Linux Kernel. I am working on migrating the design to higher kernel. Once done, I will send you the design files.
- TLemo7 years ago
Thanks for your reply. Do you have any time estimate on when the migration to the higher kernel will be completed?
Is it correct to say that with the info provided at the link, we would be able to use the design files as a sort of template to configure our own program to write data from the FPGA to HPS?
