matif
7 years agoHow to see Transceiver phy output (received parallel data) on putty terminal?
Nathan_R_Intel
Contributor
7 years agoHie,
Signaltap tool is not a simulation tool. Its similar to a logic analyzer, except it can be accessed through JTAG connection.
The transceiver registers can be accessed through AVMM; hence using a HPS to AVMM bridge will allow you to access the transceiver registers. However, the rx_paralleldata is high speed data that is not available through registers. Hence, please check if accessing the rx_paralleldata through signaltap could help meet your requirement.
Please check more details on Signaltap in the following link:
https://www.youtube.com/watch?v=DCUhsezqydQ
Nathan
matif
7 years agoOh. ok. Sorry I didn't know about that. Thanks a lot for the link. I shall check it out. Thanks a lot again.
