How to run SocWatch with OpenMPI programming?
pchau25, Thank you for posting in the Intel® Communities Support.
In order for us to be able to provide the most accurate assistance, we just wanted to confirm a few details about this matter:
Are you referring to a specific Intel® product?
What is the model of it?
Are you working in a project, design or software development plan?
If that is the case, what is the project about?
Any questions, please let me know.
Albert R.
Intel Customer Support Technician
A Contingent Worker at Intel
hi,
- I am running on our server with lscpu as
-bash-4.2$ lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 32
On-line CPU(s) list: 0-31
Thread(s) per core: 1
Core(s) per socket: 16
Socket(s): 2
NUMA node(s): 2
Vendor ID: GenuineIntel
CPU family: 6
Model: 85
Model name: Intel(R) Xeon(R) Gold 6130 CPU @ 2.10GHz
Stepping: 4
CPU MHz: 999.884
CPU max MHz: 3700.0000
CPU min MHz: 1000.0000
BogoMIPS: 4200.00
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 1024K
L3 cache: 22528K
NUMA node0 CPU(s): 0-15
NUMA node1 CPU(s): 16-31We use Centos7.
2. I am using Vtune and SoCWatch for our project. Vtune for CPU and Memory measure, SoCWatch for energy measure of our program.
3. Our program includes 1 C++ program, 1 MPI program and 1 python program.
4. our plan is that we will measure memory, CPU and energy to figure out where we need to improve out program.
5. I have the problem to run our program with SoCWatch. Please give me some example to run 3 programs with SoCWatch.
6. SoCWatch is suitable to run both C++, MPI and Python program or not?
I am try to measure energy consumption on my system.
I have an openMPI program.
To run it, we can rut with mpirun -n 4 ./hello
This program will print "hello" from 4 processes.
Now, If it is a C++ program, we can run SocWatch with it as
"sudo socwatch -m -f sys -f wakelock -t 35 -p ./hello"
With OpenMpi, I try .... -p mpirun -n 4 ./hello, But the program is stropped because socwatch did not recognize to mpirun.
Could you please tell me how to run SoCWatch with MPI?
If not, Is there any programe can measure energy consumption on linux.Thank you so much!
