wyue01
7 years agoHow to read from a Flash and write back to it with Nios Command Shell?
According to the ug_nios2_flash_programmer.pdf, I have read the data(current.srec) from flash. And then I want to write the current.srec back to flash. while the ug_nios2_flash_programmer.pdf ...
Ahmed_H_Intel1
7 years agoHi,
Which flash device you are using. Altera has many examples of how to read/write flash device. Plus which board you are using?
Please use the following link to find the required example that's suites your board and flash.
https://fpgacloud.intel.com/devstore/platform/?search=flash&category=2&acds_version=any
The examples have the How-to-use document, which will help you to understand the how to use/recreate the project.
