ZLjus
7 years agoHow to make RSFEC IP work in Stratix10 device?
I am using DEVICE 1SX280HU2F50E1VG. Enabling RS-FEC in the 100GE IP core defining widow places this device in the data path. The problem I have is I can't make the RS-FEC block work. No packets are c...
Deshi_Intel
7 years agoHI,
Yes, these are the answers that I am looking for.
Do you had a chance to try out with 100G Eth example design to see if the issue still persist ?
Also, do take note that RS-FEC block had extra IO PLL to clock it. I presume you had provided correct input clock to the 100G IP, clk_ref pin ?
Can you probe reg address 0x322 PHY_CLK bit[2:1] to see whether RS-FEC PLL is locked ? Expected value of 1
Lastly, do you still encounter this issue when internal loopback is disabled (meaning normal external data traffic transaction) ?
dlim
