ZLjus
7 years agoHow to make RSFEC IP work in Stratix10 device?
I am using DEVICE 1SX280HU2F50E1VG. Enabling RS-FEC in the 100GE IP core defining widow places this device in the data path. The problem I have is I can't make the RS-FEC block work. No packets are c...
Deshi_Intel
7 years agoHI,
- May I know which Quartus version that you are using ?
- Stratix 10 FPGA contains few Ethernet IP. Are you referring to "low latency 100G Ethernet Intel FPGA IP" or some other Ethernet IP ?
- Do you encounter the issue in simulation or actual hardware testing ?
- Can you elaborate further on your loopback testing ?
- Where do you enable the loopback path ?
- Do you observe data transfer on Tx path as you claim there is no data return on Rx path ?
- Have you tried debug using Ethernet example design that you can generate from Ethernet IP to see whether issue still persist ?
- I found some known issues with the RS-FEC feature but not sure related to your issue or not
- https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/ip/2019/why-does-the-low-latency-100g-ethernet-intel--stratix--10-fpga-i.html
dlim
- ZLjus7 years ago
Is this what you were asking?
