Naji_Naufel_Arrow
6 years agoHow to leave unused UFM Flash on MAX10 blank (0xFF)
I use the UFM to store my NIOS code but I reserve Sector 1 (16kB) for data storage (Liker Script). I use "Convert Programming File" to merge the .sof and .hex to make a .pof. After configuration, a...
Naji_Naufel_Arrow
6 years agoIn Convert Programming Files:
- Select Internal Configuration
- In Options/Boot Info ... -- select UFM source: Load memory file, navigate to ./software/<project name>/mem_init/system_onchip_flash_0.hex, keep all defaults.
- Click "SOF Data" -- click Add File..., navigate to ./output_files/<project>.sof
- Keep default Programming file type: Programmer Object File (.pof)
- Click Generate
In "Programmer":
- Check the boxes for CFM0 and UFM in the Program/Configure column
- Click Change File ..., navigate to just created .pof
- Click Start and watch MAX10 get configured
