2 years agoHow to improve Ethernet transmission speed?
I generated some image data on the Cyclone V FPGA side, sent it to DDR3 through SGDMA, and finally sent it out from the HPS side using Ethernet. However, the sending speed is not sufficient for the ...
ZiYing_Intel
2 years agoHi,
I am not sure where the bottle neck is and below is my suggestion:
- You can try to count in the video blanking area(vertical and horizontal) and do the testing again to see whether the ethernet speed issue still exist anot.
- Adjust the resolution and refresh rate
Besides that, you can refer the design in link below:
- https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-examples/design-store.html?q=niosV&s=Relevancy
- https://www.rocketboards.org/foswiki/Main/WebHome
zying
