2 years agoHow to improve Ethernet transmission speed?
I generated some image data on the Cyclone V FPGA side, sent it to DDR3 through SGDMA, and finally sent it out from the HPS side using Ethernet. However, the sending speed is not sufficient for the ...
ZiYing_Intel
2 years agoHi,
Thanks for your reply. What I means is Intellectual property (IP).
For example Ethernet IP, embedded IP or other etc....
Also , are you using provided example design ? or this is your custom design ?
ZiYing_Intel
2258432
2 years agoHello,
Sorry for misunderstanding your meaning. I downloaded the GHRD project for Cyclone V from Rocketboards and made modifications based on GHRD. On the FPGA side, I used FIFO and SGDMA IPs, but on the HPS side, I did not use IP. I did not use Ethernet IP, just wrote code on the HPS side to read the data in DDR3 and send it through the sendData function.
//main code #include <stdio.h> #include <stdint.h> #include <unistd.h> #include <fcntl.h> #include <sys/mman.h> #include "sgdma_dispatcher.h" #include "sgdma_dispatcher_regs.h" #include "ethernet_sender.h" #define DISPATCHER_CSR_BASEADDR_W 0xC0001000 #define DISPATCHER_DESC_BASEADDR_W 0xC0002000 #define DISPATCHER_CSR_BASEADDR_R 0xC0003000 #define DISPATCHER_DESC_BASEADDR_R 0xC0004000 #define HPS_MEM_STORE_STARTADDR 0x10000000 #define FRAME_WIDTH 1280 #define FRAME_HEIGHT 720 #define PIXEL_FRAME 14 #define PIXEL_SIZE 2 #define FRAME_SIZE (FRAME_WIDTH * FRAME_HEIGHT * PIXEL_FRAME * PIXEL_SIZE) int main(int argc, char* argv[]) { int mem_fd = open("/dev/mem", O_RDWR | O_SYNC); if (mem_fd == -1) { perror("Error opening /dev/mem"); return -1; } // Map the HPS DDR3 memory region to user space uint8_t* data = (uint8_t*)mmap(NULL, 0x2FFFFFFF, PROT_READ, MAP_SHARED, mem_fd, HPS_MEM_STORE_STARTADDR); if (data == MAP_FAILED) { perror("Error mapping DDR3 memory"); close(mem_fd); return -1; } // Create dispatcher control tcSGDMADispatcher write_dispatcher(DISPATCHER_CSR_BASEADDR_W, DISPATCHER_DESC_BASEADDR_W, 0); // Create descriptors tsSGDMADescriptor write_descriptor = {0}; while (1) { write_descriptor.write_addr = HPS_MEM_STORE_STARTADDR; write_descriptor.length = FRAME_SIZE; write_descriptor.control.msBits.end_on_eop = 1; write_descriptor.control.msBits.go = 1; write_dispatcher.WriteDescriptor(write_descriptor); sendData(data, FRAME_SIZE, "192.168.137.1", 12345); } // Unmap the DDR3 memory region and close /dev/mem munmap(data, 0x2FFFFFFF); close(mem_fd); return 0; }
