2 years agoHow to improve Ethernet transmission speed?
I generated some image data on the Cyclone V FPGA side, sent it to DDR3 through SGDMA, and finally sent it out from the HPS side using Ethernet. However, the sending speed is not sufficient for the ...
ZiYing_Intel
2 years agoHi,
May I know you are using which IP in your design?
zying
- 22584322 years ago
Hello Zying,
I use the Cyclone V board to send data to the PC, and the IP address of the board is 192.168.137.245, while the IP address of the PC is 192.168.137.1.
