Lilian_61
6 years agoHow to generate a full 16MB size image?
I am using quartus 19.1 Convert Programming File tool to generate .jic and rpd image by using cof.
Current the generated image size is 15MB, and due to project requirement, I need to generate...
- 6 years ago
Thanks for your reply, I have fixed this problem.
Actually I didn't pay attention to the .jic file, I focused on the .rpd file.
And I just figure out a method,that is I build a 16byte dummy hex file, which is all ’1‘, and add it at offset 0x0FFFFF0,then I could get a full 16MB size .rpd image.
JohnT_Altera
6 years agoHi,
The JIC file generated should cover fully on the flash that you are using. May I know if your using different flash then the one you selected?
Lilian_61
6 years agoHi,
