YYang79
5 years agohow to download configuration code to Cyclone 10 dev kit board for customer's power-up configuration
Hi, I have a Cyclone 10 development kit board: DK-DEV-10CX220-A. It works well with BTS. I need to download my own configuration code either to EPCQ-L(ASx4) or to the NOR flash memories on the boar...
NurAiman_M_Intel
5 years agoHi,
Perhaps you can try this steps:
- Auto detect device, right click the device and add bitstream into it
- Remove the empty device(just as I shown before in the red box)
- Hit program
On top of that, try to check whether SOF file can program or not to minimize the scope or error. If can, then there is possibility the JIC file has problem. Can try on the other version as well to check if it is version dependent.
Aiman
YYang79
5 years agoHi,
I did according to your suggestion. It did not work.
I can down load my code via JTAG by using SOF file to FPGA directly after power up. It tells us the code is working. The issue is just I could not permanently put it into the FLASH so as not to be able to boot the FPGA at power up.
I've tried revision of 17.1 and 19.1 of Quartus Prime Pro. Neither works.
