YYang79
5 years agohow to download configuration code to Cyclone 10 dev kit board for customer's power-up configuration
Hi, I have a Cyclone 10 development kit board: DK-DEV-10CX220-A. It works well with BTS. I need to download my own configuration code either to EPCQ-L(ASx4) or to the NOR flash memories on the boar...
NurAiman_M_Intel
5 years agoHi,
Kindly share the screenshot of the error and also photo of the board as we will need to see if the switch was correctly set up.
You can also check the error if you are using Quartus pro, enter the error code and press enter:
Aiman
YYang79
5 years agoHi Aiman,
i have contacted you before. My issue is still unsolved. per you request i attached the pictures.
- NurAiman_M_Intel5 years ago
Apologize for the delay in response.
JIC programming failure might be due to TCK frequency of the USB blaster II. Try to change it to 6MHz.
On top of that, please ensure to change switch to AS switches. Can refer userguide below:
Aiman
- YYang795 years ago
Would you please let me know how to change it to 6MHz?
